Wire diagram for TO35
Posted by Mickey Cook on January 20, 2004 at 03:14:56 from (24.243.168.84):
I need help with wiring a TO35. This is a 12 volt system, the alternator has a built in regulator and the key switch does the starting (no start button). I don't have lights and probably never will. I also need to know what kind of solenoid to use in this application.
Post A Followup
: Re: Wire diagram for TO35
