Re: Refurbishing ring gear teeth
Posted by 42FarmallH on January 20, 2004 at 11:23:45 from (165.234.131.75):
In Reply to: Refurbishing ring gear teeth posted by williamf on January 20, 2004 at 10:14:09:
third party image
Here is a pic of the ring gear on the W9 I got last fall, through the starter hole. Had sat for 20 years, mice built a nest in the bottom of the clutch housing and the teeth were rusted off. I don't think you could fix this with a dremel!
Personally, I would split the tractor and put a new ring gear on. No sense in going through all the work to flip the ring gear around or just turn it to a different spot...
Post A Followup
: Re: Re: Refurbishing ring gear teeth
