Re: SUPER A CARB IDENTITY
Posted by rebuilder on January 20, 2004 at 19:55:32 from (66.228.102.123):
In Reply to: SUPER A CARB IDENTITY posted by DAVID B on January 20, 2004 at 19:14:51:
David:
On the throttle body there will either be a brass tag with the carb # stamped into it or it will be stamped directly onto the throttle body. Sometimes it can be very small and difficult to see unless you clean it thoroughly. There should be two #'s(if you can read them). One number will be the I.H. part # and the other will be the Zenith part #. I.H. #'s in the book are as follows:
C-113 engine-52499DB or 352376r92
C-123 engine-355485r91 or 362384r91
I only listed the part #'s for the gas engines, not distillate or kerosene.
Post A Followup
: Re: Re: SUPER A CARB IDENTITY
