Re: Re: Re: B275 CAV fuel pump problems...help.
Posted by lee on January 20, 2004 at 21:08:18 from (24.24.92.235):
In Reply to: Re: Re: B275 CAV fuel pump problems...help. posted by Phil on January 20, 2004 at 17:35:08:
Not sure you have followed the procedure 100%.
The procedure I wrote comes from the IH operators manual. Have you tried again in warmer weather?
Dumb question, eh? Probably not much warmer there. Not very warm here in NY. Have you done steps 8, 9, 10 as written even though you can't seem to get fuel at 5 and 7. Try 1 thru 4, 6, 8, 9, 10 exactly as written. The manual pump is not used after step 7. I'm not sure you can pump fuel thru the injector pump manually. Any time I ever did this I cranked the engine after venting the injector pump.
Post A Followup
: Re: Re: Re: Re: B275 CAV fuel pump problems...help.
