Farmall Tractors Discussion Board
Re: **Sodium Silicate**
Posted by Martin caldwell on October 12, 1999 at 10:46:23 from (152.163.197.214):
In Reply to: **Sodium Silicate** posted by Merlin on October 11, 1999 at 14:17:46:
we used water glass in disel irrigation engines, we couldn't and didn't have time to shut down. sealed until we could repair in the winter. have used it to seal blocks that had internal cracks. when using anti-freeze be sure the coolant is hot, then it will mix. it is easier to run water for several hours with the water glass, then drain and add anti-freeze. careful not to use too much, one quart is more than enough in any big engine.
Post a Followup
: Re: Re: **Sodium Silicate**
