Re: What could i do to my 966 to give it more HP?
Posted by Aces on January 22, 2004 at 10:29:01 from (67.0.38.2):
In Reply to: What could i do to my 966 to give it more HP? posted by Dan on January 22, 2004 at 07:04:07:
You could put on turbo if you use your head after you put it on. It is not the same engine as 1466 the 966 had 414. You should be able to just turn it up. If the rubber hose I think that goes from pump back to the second filter the onlt hose on there has be changed and it is not the IH Part Number you can put 3 or 4 turbos on and never get more HP.
Post A Followup
: Re: Re: What could i do to my 966 to give it more HP?
