Re: water jacket plates
Posted by colekicker on January 23, 2004 at 11:26:53 from (128.194.70.143):
In Reply to: water jacket plates posted by Gordon on January 22, 2004 at 22:20:23:
I had metal cut from a local shop. Also had them bend the pieces for the water to flow through. Set my other piece up to it, drilled all the holes. Set the depth of the flow pieces and welded them in. I don't think that the 3/16 piece is going to rot through any time soon.
Post A Followup
: Re: Re: water jacket plates
