Re: Painting questions
Posted by rustyfarmall on January 23, 2004 at 13:31:46 from (216.248.75.171):
In Reply to: Painting questions posted by Chad on January 23, 2004 at 12:11:16:
Do not use the sandblaster unless you remove the individual pieces and sandblast them away from everything else, that sand goes everywhere and will get into everything. Do all of your blasting either outside or in a separate building. As far as what paint to use? The Case-IH 2150 is a very good, high quality product. It will not fade or turn colors even after several years. If you have really deep pockets you can go with the PPG, but the end product will not be any better.
Post A Followup
: Re: Re: Painting questions
