Re: Re: Probable cause of crankcase breathing (pic
Posted by Clanger on January 23, 2004 at 16:02:27 from (80.176.149.33):
In Reply to: Re: Probable cause of crankcase breathing (pic) posted by JB on January 23, 2004 at 15:25:19:
Hi JB, Just taken the oil pan off tonight. Yes the front end of the tractor is basically bolted to the engine with 8 bolts (2 columns of 4 bolts fitted vertically. I&T book says support the middle of the tractor and then remove bottom 6 bolts and loosen the top pair. You can then remove the pan bolts and remove the pan. Well I started doing this, but when I saw the front end starting to move away from the engine I stopped - it looked too scarey. So I rang a chap here in the UK that specializes in used IH for his advice as he does loads of these. He said to only remove the bottom 4 bolts and leave the top 4 done up. There is no need to support the middle of the tractor this way (although I left mine in place). Anyway I think this is a much better method. You will need to make sure you've got all the bolts out (some are hidden at the back of the pan) and then gently knock the pan down with a hammer and block of wood. I also put a car jack under the pan to help lower it as it's pretty heavy. I'll keep you posted with further developments.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
