Re: B crankshaft pulley removal
Posted by GaRY-mISS on January 24, 2004 at 17:25:51 from (152.163.252.227):
In Reply to: B crankshaft pulley removal posted by Kenneth on January 24, 2004 at 16:58:36:
i USUALLY DRILL TWO HOLES IN TE PULLEY directly across from each other, out far enough from the center so that I can reach behind with a nut and use a harmonic balancer puller or the like. Use a cap in the end of the crank. I have found a few of them to be threaded. If so, you don't want to ruin the threadsDO NOT try to driv it off with a hammer, chisel, etc. It is guaranteed that it will break and will ruin your day along with yourpocketbook.Good luck.
Post A Followup
: Re: Re: B crankshaft pulley removal
