Re: Stuck H Farmall
Posted by old on January 24, 2004 at 20:38:34 from (63.189.49.23):
In Reply to: Stuck H Farmall posted by Jim on January 24, 2004 at 19:07:45:
First fill all the cylinders with oil or tranmission fluid and walk away from it for a week, then top the cylinders off with turpentine and let that set a day or 2. If its going to brake loose it will then if it doesn't pull the head and rebuild the engine. Oh by the way I have never had an engine that didn't brake loose doing what I said to do, but theres is always a first
Post A Followup
: Re: Re: Stuck H Farmall
