Re: Re: SuperA/A?
Posted by Al on January 25, 2004 at 12:48:59 from (65.160.63.217):
In Reply to: Re: SuperA/A? posted by Al on January 25, 2004 at 12:40:21:
I re-read your post from above: Super A will have conical head bolts and studs on the back for the drawbar, heavier fenders, etc. You may have had someone replace the seat bracket, they will rust out. Another way is look for casting codes. These will be found on block, trans. case and other major cast components. They are cast as MM/DD/Y where the year is represented usually as a letter:
Example: Jan. 25, 1948
1 25 R
Year codes:
39: I
40: J
41: K
42: L
43: M
44: N
45: O
46: P
47: Q
48: R
49: S
50: T
51: U or W
52: X
53: Y
54: Z
HTH
Al
Post A Followup
: Re: Re: Re: SuperA/A?
