Re: super c 6v or 12v
Posted by Brownie 450 on April 01, 2009 at 03:52:22 from (216.51.158.151):
In Reply to: super c 6v or 12v posted by johndd on March 31, 2009 at 16:55:38:
If the generator has a red label [Delco Remey] it is probably not 6-volt. See if you can find the voltage regulator on a bracket just below the generator. Is it "hooked up" yet?? If so, it will have a 6 P if it is 6-volt or 12 P [maybe N] if it has a 12-volt generator --stamped on the mounting tab. This assumes a Delco regulator.
