Re: 1944 farmall H Axle seals
Posted by Stuart on January 27, 2004 at 07:47:42 from (137.104.169.19):
In Reply to: 1944 farmall H Axle seals posted by Mark on January 27, 2004 at 07:15:27:
You have to remove the wheels to perform this operation. The biggest job will be to get the wheels off, depending on how rusty they are. The oil seals in general are not that hard to change.I am not sure if you have to drain the oil but I am guessing because there is a seal there you could find oil once it is removed.
Hope this helps, Good luck
Post A Followup
: Re: Re: 1944 farmall H Axle seals
