Re: REAR AXLE LEAK IN 400 FARMALL
Posted by Randy in NE on January 27, 2004 at 11:12:46 from (216.58.237.20):
In Reply to: REAR AXLE LEAK IN 400 FARMALL posted by ABANE on January 27, 2004 at 10:57:24:
There is an oil seal and felt washer at the out end of the axle tube. You need to remove the rear wheel and then remove the end cap. There is a gasket between the rear-end housing and the axle tube. This will require getting into the rear-end to remove the two bolts holding the axle retaining cap.
Post A Followup
: Re: Re: REAR AXLE LEAK IN 400 FARMALL
