Re: 1944 farmall H Axle seals
Posted by mbnok on January 27, 2004 at 11:49:36 from (216.226.31.6):
In Reply to: 1944 farmall H Axle seals posted by Mark on January 27, 2004 at 07:15:27:
Set the tractor so that the seal is a little higher than your check plug. If you have the transmission fluid to that level. It sometimes makes it harder to get the wheel off so raise it after you take your wheel off.
Post A Followup
: Re: Re: 1944 farmall H Axle seals
