Re: REAR AXLE LEAK IN 400 FARMALL
Posted by mbnok on January 27, 2004 at 12:06:36 from (216.226.31.6):
In Reply to: REAR AXLE LEAK IN 400 FARMALL posted by ABANE on January 27, 2004 at 10:57:24:
If its the gasket between the axel housing and transmission you might try what worked for me. When my 400 got worse I took the wheel off and then loosend the axel housing, it had been some time since I had taken a H apart so I forgot about having to go into the rear end to get the housing off, but it moved out a little and with a small screwdriver worked silicone gasket maker up between the mating surfaces. Worked fine for me.
Post A Followup
: Re: Re: REAR AXLE LEAK IN 400 FARMALL
