Re: Shifter build up
Posted by Larry on January 27, 2004 at 16:43:52 from (216.37.23.112):
In Reply to: Shifter build up posted by 49 Cubber! on January 27, 2004 at 16:24:06:
You need the knob to just go into the shifter rails amd long enough to go to the bottom of the notch when the transmission is in neutral. If your H is jumping out of gear, it probably has a worn gear. If you are having trouble with the shifter not reurning the transmission to neutral, check the cross pin and the hole in the transmission top for wear. If this is the problem I put a fix on about 6 months ago.
Post A Followup
: Re: Re: Shifter build up
