Re: REAR AXLE LEAK IN 400 FARMALL
Posted by Adam on January 27, 2004 at 19:52:22 from (69.66.79.29):
In Reply to: REAR AXLE LEAK IN 400 FARMALL posted by ABANE on January 27, 2004 at 10:57:24:
If you do get into the rearend you should look things over for worn or broken parts. We did this to our H and found a bad bearing and a worn sliding gear that needed replaced.
Adam
Post A Followup
: Re: Re: REAR AXLE LEAK IN 400 FARMALL
