Re: mounting tire chains
Posted by JB on January 30, 2004 at 19:49:10 from (24.157.143.220):
In Reply to: mounting tire chains posted by dave on January 30, 2004 at 18:30:54:
Hi, this is how we install spike chains one wheel at a time.
Lay chain out behind wheel, run a couple of loops of baler twine through hole between rim and center disk, tie baler twine to side and center links of chains, drive tractor forward very slowly until chains have wrapped around tire or ends are at a spot that you can easily reach the inside of the wheel to connect the chain hooks.
Connect center links and tighten side chains and cut off baler twine.
This method works better if you have 2 people, 1 to drive the tractor and the other to guide the chains over the tire.
Good luck
JB
Post A Followup
: Re: Re: mounting tire chains
