Re: Hydraulic strength?
Posted by Haas on January 31, 2004 at 10:13:00 from (12.65.72.84):
In Reply to: Hydraulic strength? posted by tim on January 30, 2004 at 19:02:31:
The Super C hydraulic pump will put out about 1200 psi maximum pressure. Not sure what the flow is. More modern tractor hydraulics are usually 2000 to 2500 psi. You can compensate by using a larger cylinder, which of course takes more volume and will operate slower.
Post A Followup
: Re: Re: Hydraulic strength?
