Re: H Oil Pressure
Posted by Wayne Swenson on January 31, 2004 at 20:46:07 from (66.228.234.77):
In Reply to: H Oil Pressure posted by BB on January 31, 2004 at 19:01:33:
What weight oil are you using?
The only way I know to check engine oil pressure accurately is to find a mechanic that you can borrow a "master oil pressure" gauge from and temporarily replace the tractor's gauge with the test gauge.
You do not need a huge amount of pressure to lube the engine; flow volume is more critical.
If the rocker arms are getting enough oil when the engine is hot & idling then I would not be too worried.
Post A Followup
: Re: Re: H Oil Pressure
