Re: H Oil Pressure
Posted by rustyfarmall on February 01, 2004 at 04:56:39 from (199.120.81.200):
In Reply to: H Oil Pressure posted by BB on January 31, 2004 at 19:01:33:
I have an H that does the same thing. I am using a straight 30 weight motor oil, and the oil is fresh, so I know that is not the problem. I have been told that I need to to check out the relief valve in the oil pump. I also know that worn main, rod, and cam bearings will produce the same effect, but the engine on mine runs very good and sounds like a good tight engine, so I am leaning towards the relief valve.
Post A Followup
: Re: Re: H Oil Pressure
