Re: H Oil Pressure
Posted by Irv on February 01, 2004 at 13:51:22 from (205.188.209.82):
In Reply to: H Oil Pressure posted by BB on January 31, 2004 at 19:01:33:
I rebuilt the oil pump in my H several years ago. The gears are hardened, so the will wear less than the pump body, which is cast iron. These geared pumps will always push the gears to the top of the pump - into the cover. If you take the cover off you will see the marks the gear makes. To rebuild it - take the cover off. See if there are any shims under the cover. The headspacing in the pump is important. Usually there is one paper shim here. Take the cover to a machine shop - have the inner surface ground flat - Then reassemble - if the gears are tight - put a shim in - the thinner the better. An .001 increase in headspace can cause a signifigant loss in pressure. You can see some difference when the oil gets hot, but this fix has worked on mine for years. Irv
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
