Farmall Tractors Discussion Board
What are you using to protect wires.
Posted by Marvin on October 14, 1999 at 10:51:40 from (134.134.248.22):
When you have done rewires on your tractor, what have you wrapped the wies with to protect them from abrasion. The original had a cotton like material.
Panduit makes some Spiral wrap, corrugated tubing with a slit down the side and a braided sleeve.
I have seen on automobiles that the corrogated does not hold up very well over time. The spiral would be good so that you can split wires off of the bundle where you need to.
What have each of you used and what has held up the beat and protected the wire the best.
Thanks
Post a Followup
: Re: What are you using to protect wires.
