Re: hydraulic oil for H ?
Posted by Dave in CT on February 03, 2004 at 15:46:12 from (64.252.222.206):
In Reply to: hydraulic oil for H ? posted by riverbend on February 03, 2004 at 08:25:10:
All the IH and I&T literature I've seen on Hs say straight 30W non-detergent oil in the hydraulics. I don't know about the detergent status of Hy/Trans oil but the system is designed for 30W and it must be non-detergent as the detergent oil will foam and give you no performance. There have been some other postings discussing using hy/trans in colder weather. I've used 30W in temps down to 0F with only a little initial slugishness - otherwise, no problem. Since contaminants contribute to the death of any hydraulic system, I'd like to find a way to filter the lift-all oil on my H. I imagine that would require some live or quasi-live conversion setup in order to get all the oil to flow through it.
Post A Followup
: Re: Re: hydraulic oil for H ?
