Re: Re: Re: MD compression
Posted by Farmaller on February 04, 2004 at 04:01:22 from (152.163.252.227):
In Reply to: Re: Re: MD compression posted by Ray on February 03, 2004 at 19:48:50:
It sounds like it not timed exactly right. When no.1 is TDC you should be on pulley mark also. Then see where rotor is lined with mag cap. Remember trips at TDC on compression stroke. Then make sure plug wires in right order. mags on MD turns opposite. Doesn,t sound like it was stuck real bad so that is a good sign. However a lot of tractors were parked because of burnt valve. This thing should run. Keep in touch.
Post A Followup
: Re: Re: Re: Re: MD compression
