Re: A won't start under 32 deg f
Posted by Bob M on February 04, 2004 at 07:34:36 from (165.170.128.65):
In Reply to: A won't start under 32 deg f posted by jab on February 04, 2004 at 06:12:43:
As the others suggest change to a lighter or multviscosity oil. I use 15W-40 year round in my 6 volt Super H and MM “U”. They crank and start reliably at 0 deg and below. (I’m in cold, snowy NY too...)
However if it cranks slow even when jumped on 12 volts you may have an electrical problem also. Look for undersized battery cables, bad cable terminals, worn out starter switch, a worn out/stuck starter brush or a bad solder connection inside the starter.
Post A Followup
: Re: Re: A won't start under 32 deg f
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
