Re: Re: Re: Should I clean the rocker assembly or
Posted by Mr. J on February 04, 2004 at 16:21:41 from (67.30.69.186):
In Reply to: Re: Re: Should I clean the rocker assembly or leav posted by clanger on February 04, 2004 at 15:07:09:
Clanger,
As easy as it is to dissamble the rocker assembly, I believe that I would go ahead and dissamble the assembly and clean the bearing surfaces of the rocker arms....Have cleaned several without disassembly without any problems, but, the older I get the more I learn to do something right the first time. I think getting older and calmer I learn to work smarter and not faster....make less mistakes that way...The problem is that I am only 25. Anyway, good luck with your tractor,
Jared Jeffries
Post A Followup
: Re: Re: Re: Re: Should I clean the rocker assembly or
