Re: Re: Farmall A with a 60 Woods belly mower
Posted by Haas on February 04, 2004 at 18:22:56 from (12.65.48.108):
In Reply to: Re: Farmall A with a 60 Woods belly mower posted by big lawn in Wi on February 04, 2004 at 17:37:31:
The A and the B have the same engine and transmission. Difference is the rear and front wheel set up. Of course the B has the narrow front with a different steering gear. The B is also wider in the rear, as although you sit offset, the tractor is not offset. The A is offset design with an extension only on one side of the differential whereas the B has the extension on both sides making it quite a bit wider in the rear. The A was intended as a one row tractor, where the B was set up to do two rows at a time. Used as a mower tractor, I would think performance would be about the same.
Post A Followup
: Re: Re: Re: Farmall A with a 60 Woods belly mower
