Re: re-threading exhaust manifold
Posted by Dave on February 05, 2004 at 04:54:52 from (24.33.238.155):
In Reply to: re-threading exhaust manifold posted by James on February 03, 2004 at 04:59:19:
I've done this twice. Both times I was able to use a chisel and hammer to remove the old rusted, broken pipe. Them I took a thread file and cleaned up the threads, then went to the hardware, bought a nipple threaded on both ends. Cut it in half. Used one end to run down inside to clean the threads and make them a little deaper (Actually just cleaned the previouly unused threaded portion, and used the other as my new pipe......
Post A Followup
: Re: Re: re-threading exhaust manifold
