Re: please help..can't get a MD started!
Posted by Haas on February 05, 2004 at 10:46:10 from (12.65.49.200):
In Reply to: please help..can't get a MD started! posted by casey on February 05, 2004 at 09:56:19:
Procedure calls for switching back to gas side for shutdown, then shutting off the gas to the carb and running all the gas out. After doing this be sure to switch back to diesel so the decompression valves will be on their seats to cool. If not on the diesel side after shutdown, the valves can warp. However, if it takes 30 minutes of fiddling to get it going, I doubt that the shutdown procedure is your problem on starting. I grew up on one of these things, and we never switched to gas for shut down. We always just pushed the throttle lever down to shut off and left it. Never had much trouble starting it. So...I expect you have some problem with the starting set up. You need to check that all is working as designed on the switch over system. Do you have a good ignition spark and is the switch located in the front of the manifold still connected and working correctly. The chamber in the front of the manifold is where the ignition switch is located to ground the magneto and shut off the spark, That swithc is operated by the switch over lever. The switchover lever also works butterflys in the manifold to direct air through the carb on the gas side. Also, works the float in the carb so that it is raised up on the diesel side to stop gas flow. Check that you are getting gas flow on the gas side by opening the petcock on the carb with lever in gas position. And finally, check the operation of the decompression valves which are also operated by the switch over lever. There is a clearance setting for these and they may not be opening enough. YOu have to remove the valve cover to set this valve clearance. I find in starting my MD, that it takes full choke for it to start even in warm weather and then gradually decreasing choke as it warms. Usually starts on about the third crank, even after sitting for quite a while.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
