Re: Re: Fuel viscosity
Posted by jed on February 05, 2004 at 11:15:25 from (66.212.143.210):
In Reply to: Re: Fuel viscosity posted by JPY on February 05, 2004 at 10:06:53:
Your are not moving the flash point to the kero. Your are adjusting the end point to lower the end point to max fuel production. Gasoline with RVP gets the RVP from Butane, which goes from a gas to a liquid at 33 degrees F. I don't know where you are coming up with the 60 degree flash point for gasoline, but I feel certain you would blow your head off testing the flash point of gasoline. It flashes at - numbers. Your info on end point always being 425 is wrong. Have you checked the gasoline you are buying? My guess would be that you haven't. We do it everyday for clients at the fuels testing lab. My opinion is based on 20 plus years of refinery and lab testing experience, for what that it is worth.
Post A Followup
: Re: Re: Re: Fuel viscosity
