Re: 856 width variation specs
Posted by Ron 1456 on February 05, 2004 at 16:15:52 from (207.32.34.59):
In Reply to: 856 width variation specs posted by riverrat on February 05, 2004 at 15:35:29:
It depends on where the cast wheels are clamped to the rims. If the wheel tread is set for 30inch rows it should fit you trailer. If the cast wheels are clamped to the inside bead on the rims you may not be able to slide the wheel in far enough on the axle to get it on your trailer. Changing the wheel tread by moving the clamps to the outside bead on the rim is not really that hard but it does take a while to do it. Plus a good heavy hydraulic jack.
Post A Followup
: Re: Re: 856 width variation specs
