Farmall Tractors Discussion Board
Re: Super C Brakes not braking
Posted by Farmer Bob on October 14, 1999 at 22:20:07 from (207.227.185.128):
In Reply to: Super C Brakes not braking posted by Bama Binder on October 14, 1999 at 13:04:28:
Bama,
What ever you do, do not use any kind of lubricant inside the brake drum. The actuator disk has the large balls (4 of them) inside of it which ride in a oblong cavity. They must be free of rust and any other debris that may inhibit brake action. The two halves of the actuator are held together with two pretty stiff short springs. Check these for condition as well as the brake return spring that fits over the adjustment bolt inside of the drum. Good luck with her and happy braking.:<)
Post a Followup
: Re: Re: Super C Brakes not braking
