Re: Before and after carb rebuild
Posted by mkirsch on April 01, 2009 at 06:27:35 from (64.80.108.55):
In Reply to: Before and after carb rebuild posted by ed in cny on April 01, 2009 at 06:19:53:
The instructions that came with the carb rebuild kit should have that information. As I recall:
The screw down on the bowl of the carb toward the bottom is the load screw.
The screw up near the neck on the rear of the carb is the idle screw.
Idle speed adjusment screw is the one where the governor shaft goes in to the carb.
