Farmall Tractors Discussion Board
Re: Re: Re: Super C..
Posted by Farmer Bob on October 14, 1999 at 22:33:01 from (207.227.185.128):
In Reply to: Re: Re: Super C.. posted by Lyle on October 13, 1999 at 16:23:06:
Be careful changing the pistons as you should probably check the distributor as well..Fly weights might be different with the firecraters than the original equipment pistons. You don't want to screw up the advance of the distributor and not have the little girl run rough after all that work.:<)
Post a Followup
: Re: Re: Re: Re: Super C..
