Re: 806 3pt weak
Posted by Chuck's Repair on February 07, 2004 at 19:08:06 from (216.170.58.10):
In Reply to: 806 3pt weak posted by mike on February 07, 2004 at 14:48:03:
Remove the three point upper link cover.Start the tractor and pull an auxillary lever and watch to see where the hyd oil is dumping from.If it dumping from the top middle aroud the lift cyl then you have a blown o ring between the valve body and the three point cyl or a valve leaking or out of adjustment.
Post A Followup
: Re: Re: 806 3pt weak
