Re: 806 motor swap
Posted by Tbear on February 08, 2004 at 08:27:14 from (205.188.209.82):
In Reply to: 806 motor swap posted by john on February 07, 2004 at 14:13:15:
I know of someone who made the same switch only it was a 1206.They took a piece of square tubing and capped the ends and welded proper fittings on either end to match the outlets.It will work with the origional frame rails but it will be a tight fit.If you use 66 frame rails you will have to lengthen the hood.
Post A Followup
: Re: Re: 806 motor swap
