Re: 450 Farmall
Posted by CNKS on February 08, 2004 at 11:14:15 from (207.178.99.147):
In Reply to: 450 Farmall posted by Jeff on February 08, 2004 at 11:04:42:
Proably a fuel flow problem, caused by crud in the tank and/or fuel lines. Shine a light into your gas tank and see how clean it is. Hopefully it won't require cleaning. Remove and blow out the fuel line. There is a metal filter inside the fitting on the carb that the fuel line screws into. Would not hurt to clean and put a kit in the carb. Does not really sound like an electrical problem, if the tractor continues to run after it starts missing. If it dies soon after, you could need a condensor or a coil.
Post A Followup
: Re: Re: 450 Farmall
