Re: carb repair ,help needed./ super a
Posted by Mr. Goodwinch on February 08, 2004 at 17:46:54 from (65.172.224.78):
In Reply to: carb repair ,help needed./ super a posted by Jon in OHIO on February 08, 2004 at 15:49:51:
Jon, I believe if I had just paid to have the carb. rebuilt, I would take it back to the rebuilder and get my money back. Show him what you found when you tore into it yourself and ask for an explanation. Don't have to be confrontational, but it is your money.
Now to the problem ,If you have to drill out the offending jet, proceed with caution. I have used a few "left" hand drill bits to remove broken or rounded off parts. The heat of the drill bit along with the combination of it spinning backwards usually does the trick.
Post A Followup
: Re: Re: carb repair ,help needed./ super a
