Re: 1086 check valves
Posted by Ted in NE on April 01, 2009 at 06:37:20 from (74.85.105.108):
In Reply to: 1086 check valves posted by Matman on March 31, 2009 at 18:33:18:
Check valves were a factory option or clould be ordered & installed later. Used to keep a heavy implement from setteling. You could remove them and replace the steel lines with hoses. Have also cut one end of the steel line and used a compression fitting made for that purpose the extend the line on back to the coupler body. Will work fine.
Ted
