Re: Need engine help
Posted by Tom of Minnesota on February 09, 2004 at 19:07:14 from (165.247.253.103):
In Reply to: Need engine help posted by Bob Brademann on February 08, 2004 at 06:02:04:
Bob, I had a similar problem with my B. For some time, it was leaking coolant into the oil. I finally pulled the head and discovered a large crack running from the inside of the #1 cylinder to the inside of the #4 cylinder. I didn't think the water was getting into the oil through the crack, so I called a Farmall mechanic friend. He said to drain the oil, pour coolant into the water jacket and place a container under the oil drain. The next day, the container contained several tablespoons of coolant. I repeated the test several times, with the same results each time. This meant the O rings on the wet sleeves were bad. My friend said that, years ago, they used to fix cracks like this in Allis Chalmers and Farmall blocks by drilling a hole through the entire block between cylinders #2 and #3 an inch or two below the top. Then they'd insert a threaded bolt. The old-timers would then put some sealer on the ends of the bolt, slip on a washer or two, then add a nut on each side and tighten them until the crack squeezed together. He said this would hold things in place for a long time. But because my O rings were leaking, I decided to find a used block and then had a machine shop build me a new engine. It cost 10 times more than I paid for the tractor when my wife bought it for me back in 1972, but I didn't care. After all those years of yeoman service, I just couldn't abandon the old girl in her time of need. Now she runs like a young colt. As long as your A wasn't leaking coolant, you might get by with the old block. But I wouldn't weld anything. Several experts told me that once you weld a block, you have to have it re-machined to make sure everything is square and true. It's not cheap, they say. Try patching yours. It might last for years. Good luck.
Home
| Forums
Today's Featured Article -
Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
