Posted by John T on April 01, 2009 at 06:39:04 from (66.244.97.31):
In Reply to: charging post #3 posted by chad from michigan on March 31, 2009 at 18:10:19:
Chad, Seems like I already provided you this info a time or two but here it is one more time,,,its taken from my Troubleshooting Procedure Para 5, see below:::
5. a) VOLTAGE REGULATOR SYSTEM: With the tractor running, temporarily ground the Gens Field post to case. If she charges then but NOT otherwise, the VR may be bad, or a wires missing from VR"s Field post to the Field terminal on the VR, or the VR isn’t well grounded.
Now to your specific questions:
QUESTION I then ran wide open and it was up to 0 and it would go above every so often. so with that said I am thinking if the vr was really junk the amp gage would be below 0 amps all the time?
NOT SO: Its a matter of HOW BAD OR HOW MUCH OUT OF ADJUSTMENT... Yes it may well be bad or else it needs adjusted, try Jims adjustments or else go to Jim at Agri Services in New York www.wiringharnesses.com and get a new VR
QUESTION: DO you think it just needs adjusting seems like at full throtal it would be 5-8 amps easy? and at idle possible 0 amps?
NO I think its bad butttttttt try Jims adjustment first n if that dont fix it see above
NOTE: The help we all work so hard to provide requires the posteR have some basic mechanical skills and experience buttttttttttttt if thats not the case take it to a professional rebuilder to get it fixed.. ITS IMPOSIBLE TO PUT IN A PARAGRAPH HERE WHAT IT TAKES ENTIRE BOOKS TO EXPLAIN AND/OR EXPERIENCE
God Bless n good wishes let us all know what happens
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
