Re: IH Power Units on Sawmills
Posted by Bob M on February 11, 2004 at 08:46:28 from (165.170.128.65):
In Reply to: IH Power Units on Sawmills posted by Wayne Kittler on February 11, 2004 at 05:42:38:
I recall there sawmills around here run by everything from U-2 to a UD-18 power units, depending on mill size. Most common however seemed to be the -6 and -9, both U and UD flavor.
Power to the mill was taken by belt from a Rockford (or Twin Disc?) PTO on the flywheel end of the engine. However in the case of the UD-18 the power unit was direct connected to a generator, then separate electric motors ran the saw and accessory drives.
For some reason MM power gasoline units were also popular on sawmills around here. And there was at least one each Caterpillar and Detroit 4-71 diesel. The Detroit-powered mill you could hear running several miles away on a still day!
Post A Followup
: Re: Re: IH Power Units on Sawmills
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
