Re: SUPER A ADDITIONAL HYDRALICS
Posted by Haas on February 11, 2004 at 12:49:52 from (12.65.61.178):
In Reply to: SUPER A ADDITIONAL HYDRALICS posted by scruffy on February 11, 2004 at 11:47:32:
You will need to buy a block that goes under the hydraulic manifold connection to the touch control unit. It goes between the manifold and the touch control unit. This will give you ports that you can connect your remote to. This will allow you to continue to use the touch control hydraulics, as well as the new unit. You can buy the block and the new remote valve from Saginaw County Tractor. I don't know if the price has changed or not, but it used to be $99 for the block and the control valve. They do not supply any hoses which will also be needed.
Post A Followup
: Re: Re: SUPER A ADDITIONAL HYDRALICS
