Re: Belt Drive Hammer Mill
Posted by Vern MN on February 11, 2004 at 18:44:15 from (64.12.97.12):
In Reply to: Belt Drive Hammer Mill posted by Ted on February 11, 2004 at 05:19:59:
We had hammer mills for a number of years to grind feed for our dairy herd. Used Hs M and a 460.
You want to check what rpm is required for the hammermill by either the data plate or instruction book. Pulley size will regulate the cylinder speed and you want to run your tractor at full throttle for power.
depending on how the hammermill is oriented to the tractor, for right rotation, a twist in the belt will prevent slapping. And as already stated each belt has its own personality. Longer the belt the more sag will show. As for the creeping, that is how square you line up.
Post A Followup
: Re: Re: Belt Drive Hammer Mill
