Re: Post rebuild run-in procedure??
Posted by riverbend on February 12, 2004 at 07:37:16 from (208.160.33.114):
In Reply to: Post rebuild run-in procedure?? posted by clanger on February 12, 2004 at 07:12:53:
The instructions that came with the pistons and sleeves for my H said to put oil in it and start it a idle. Once it is running advance the speed gradually to 1500 rpm and check for oil pressure, leaks, odd noises, etc. Run it at 3/4 throttle until normal operating temperature is reached. It warns against operating the engine at low idle. Check the carb adjustment and timing.
There is also a little chart that says after it warms up with no load, to run it 1/2 hour at rated rpm and 1/4 load, 1/2 hour with 1/2 load, 1/2 hour at 3/4 load, and 1 hour at full load. How you do that without a dyno, I am not sure.
The instructions say to retorque the head after the 1 hour, full load run. And to avoid over-loads, excessive idling and no-load operation for the first 100 hours.
If you have a new cam or had the old cam reground, you should not let it idle for the first twenty minutes or so.
I changed the oil after about 2 hours.
Post A Followup
: Re: Re: Post rebuild run-in procedure??
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
