M Farmall Clutch
Posted by farmalljim on February 12, 2004 at 13:41:07 from (167.7.7.217):
M Farmall CLUTCH does not disengage to allow changing gears while running and clutch pedal is fully pushed in. Previously there was low tolerance and when gears were changed, it would grind before finally allowing to go into gear. It now will not allow you to put in gear while running.
Possible cause, type repairs needed? Trouble shooting?
Post A Followup
: Re: M Farmall Clutch
