Farmall Tractors Discussion Board
Re: help with a International load star.
Posted by Redfan on October 15, 1999 at 14:13:52 from (203.87.53.9):
In Reply to: help with a International load star. posted by ratskinner on October 15, 1999 at 12:30:37:
Ratskinner,(well that's what it says on my computer)I've come across this problem before on our IH trucks.They obviously aren't Loadstars but I would imagine the Australian IH trucks are very similiar.Just check if there is a flexible rubber brake line from the Master Cylinder to the steel line supplying the fluid to the booster. On ours this line becomes soft after many years of use and the line swells internally, thus restricting the return of fluid to the master cylinder after application,causing the brakes to lock on.Might be the problem. Regards, Redfan.
Post a Followup
: Re: Re: help with a International load star.
